Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Archive Scene Error - Zip64 Extensions?
11 REPLIES 11
Message 1 of 12
laura.jolly
3301 Views, 11 Replies
I am trying to archive a scene to pass on for checks and am receiving an error that says "Zipfile size would require ZIP64 Extensions" and then fails to archive my scene, probably because it's too large.
How and where do I get the extensions I need for this? Can I get around this issue? There is literally zero documentation about this that I've found. I would appreciate any help, as this is a very time sensitive matter. Thank you in advance!
11 REPLIES 11
Message 2 of 12
Hi @laura.jolly,
can you tell me how big your scene is when it is not zipped yet?
On which OS are you running Maya?
Best, Nadja
Nadja Bueckmann
Technical Support Specialist – M&E (3ds Max, Maya)
Message 3 of 12
Hello, the scene file I'm trying to archive is just under a gig big, but may be trying to archive  up to 10 gigs worth of attached data. I am also using Windows 10 on a 64 bit computer for this archive. Thank you for your patience and help!
Message 4 of 12
Hello are you still available to help?
Message 5 of 12
in reply to: laura.jolly
Did you ever get an answer to this question.  I'm having the exact same issue.
Message 6 of 12
laura.jolly
No, I never got a fix on this issue, sorry. :C
Message 7 of 12
no4access
hi there i did some research i found that the limitation  inside the python script it self its not allow to archive the files that to large i found some code but i am not coder so i didn't get chance to get it work may be its help
check this link:
http://stackoverflow.com/questions/29830531/python-using-zip64-extensions-when-compressing-large-fil...
Message 8 of 12
in reply to: no4access
We had the same issue yesterday (win10 64bit, Maya 2016).
In order to try if the allowZip64 flag would fix the issue we have modified the python file:
Maya2016\Python\Lib\site-packages\maya\app\general\zipScene.py.txt
It worked great.
Here are the steps if you want to fix it:
 - go to your Maya installation folder
 - go to folder Python\Lib\site-packages\maya\app\general
 - edit file zipScene.py.txt in a text editor (notepad++, sublime or simply notepad)
 - go to line 62
zip=zipfile.ZipFile(zipFileName, 'w', zipfile.ZIP_DEFLATED)
  - add the allowZip64 flag
zip=zipfile.ZipFile(zipFileName, 'w', zipfile.ZIP_DEFLATED, allowZip64=True)
 - save the file (overwrite)
Now you should be able to create large archive files for your Maya scenes.
Message 9 of 12
It would be cool if Autodesk could check if this is a feasible solution. If so, a patch would be highly appreciated; if not, then it would be good to know if there is any other official workaround.
Message 10 of 12
the filename is zipScene.py
Message 11 of 12
This keeps happening in Maya 2018.2
Wake up!
Message 12 of 12
This solution (allowZip64=True) works for me. I'm archiving a ton of assets and the largest ZIP file so far is 9.5GB.
