- Mute
- Permalink
- Report
I have a file with many alembic caches. They are kept in the project/cache/alembic folder. If I move the entire project to another computer to render, when I open the scene, all of the alembic caches are missing in the viewport but are still showing in the Outliner. If I click on the file in the outliner and then go to attributes and try to update the cache (which is showing the correct location for the cache) it says "Alembic cache re-pathing is not supported" and it doesn't show up even though I am not really re-pathing.
I can re-import the cache but I lose the textures, start point, weeding of un-needed items, etc. I have tried this with two different outside computers and also tried it with a simple test project with one alembic file and I get the same issue when opening scenes that have been moved to another computer even though the correct project has been set.
I saw that others have had the problem but they just imported it again. I don't have that option when I send it somewhere where they can't do that. https://forums.autodesk.com/t5/maya-forum/change-pc-alembic-missing/m-p/7357345#M46575
Is there a workaround for this? Maybe something I am supposed to do before moving the project? Thanks.
