Advanced Skeleton Facial Rig Problem- Lip setting error
I use AdvancedSkeleton v.5.672 to rig character.
I can't set LipMain and LipInner when doing facial rigging,
it always shows // Error: line 0: Need at least (degree + 1) control vertices to create a curve span //
But I can succesfully set it from LipInner to LipOuter.
And there will be another problem when building AdvancedFace,
it shows "No object matches name: LipInnerAreaMesh"
What should I do? Did my 3d model have problem?
I will appreciate it if someone could answer my question.
I was having this same issue. I fixed by updating to Advanced Skeleton version 5.678.
spezialis
I have the same issue and updating to last version doesn't seem to fix the problem. Did someone fund a solution on how to fix this problem?
see this tutorial and follow it will help you
https://www.youtube.com/watch?v=J20LzJ2WtE4
nadyabw
Observer
Observer
I have the same problem. The video does not contain any solution.
hey I got the same error so DM to advance skeleton FB page,
They sent me this Youtube Video link
Its was very usefull
https://www.youtube.com/watch?v=kz4NaLGMtQg&t=537s&ab_channel=AdvancedSkeleton
Watch it from 8:30
It is error caused by non-semetrical Model
They have perfect solution
Please let me know if yor issue got solved
