Message 1 of 1
Adding Bump/Normal Map and Specular Map
04:00 AM
- Mute
- Permalink
- Report
I've used Maya Student Version for awhile now and I am using it for a project I am working on. I noticed that once I texture painted my object in Mari and imported it into Maya, I encounter some errors. For Bump/Normal maps, I tried using Phong material and it works, but using Blinn material does not. Then I tried to use my specular map by plugging it into a file node under the specular color, but nothing works. I also tried using renderman textures but only the diffuse shader was read, and both the bump/normal and specular maps were not able to be read. Is there something I should know and if there is a solution to this, it would be greatly appreciated.
