Adding a separator to custom shelf Maya 2018
Message 1 of 11
I am currently setting up my maya 2018 shelves, but from what little information I can find on the forum, I am not able to find a way to create the separator in order to divide and organise my tools.
Replies (10)
Message 2 of 11
sean.heasley
Hi @Anonymous and welcome to the community!
I'm a little bit confused by "seperator". Do you mean how to make your tools a separate tab like the poly modeling tab for example?
If so to do that, all you have to do is:
1. Select the small gear next on the left of the shelves
2. Create New Shelf
3. Name your shelf
4. Add hotkeys/tools etc to new shelf
I hope this helps solve your issue but please feel free to let me know if the issue is still occurring and we can troubleshoot further!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Message 3 of 11
sean.heasley
Hi @Anonymous
I'm just checking in to see if you need any more help with the custom shelves. Did the steps I provided yesterday help solve your issue?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 4 of 11
Hi Sean, I'm afraid I may not have made my question clear enough. The separator is what can be placed on the shelf, it is essentially a small divider between tools in order to better group a set of tools on a single shelf. You can see the separators on the default shelves within maya (small unclickable verticle lines dividing sections of the shelf up). The previous version of Maya I used (2016) had a simple method of placing separators on the shelf within the bonus tools section. If you know of a way to placing separators in Maya 2018, that would be really appreciated.
Declan Harris
Related forum post ive found - https://forums.autodesk.com/t5/maya-forum/2016-adding-separators-to-shelves/td-p/5608220
[https://autodesk.i.lithium.com/t5/image/serverpage/avatar-name/default/avatar-theme/chrome/avatar-co...]
Solved: 2016: Adding separators to shelves - Autodesk ...
forums.autodesk.com
Solved: Due to all of the UI changes re: icons etc. in 2016, I elected to not migrate my 2015 configuration when installing 2016. Now I'm recreating
Message 5 of 11
sean.heasley
Hi @Anonymous
Ah ok thank you for clarifying! You are correct that Bonus Tools has a nice simple tool that adds a separator and I just tested this and it works in Maya 2018!
We just released bonus tools for Maya 2018 a little while ago and you can download it here!
It should work fine for you as it just did for me and to clarify I'm on Update 1 of 2018.
I hope this solves your issue but please let me know if it doesn't and we can look into it further!
Message 6 of 11
sean.heasley
Hi @Anonymous
I'm just checking in to see if you need more help with getting the separator to work. Did the suggestion Ito use Bonus Tools for Maya 2018 I provided yesterday help you at all?
Message 7 of 11
Hi Sean, thank you very much for your help, the bonus tools add-on was the solution as you said. As an additional bonus, the bonus tools add-on also contained many features I'm thoroughly enjoying. Cheers for the help 😊
Message 8 of 11
Hi there,
I'm trying to figure out how to add the separator but still can't... already installed the Bonus Tools but still stuck. help!
Thanks in advance.
BTW, I'm really new using Maya, so please be patient 🙂
Message 9 of 11
Nevermind... Just found the new menu that allowed me to do it... thanks!
Message 10 of 11
How to use the bonus tools?  I am stuck when trying to add the seperators.
Message 11 of 11
luka3rd
No, your question was right from the start...!
Thanks for asking 🙂
