Maya Dynamics
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya dynamics topics.
Maya fluid explosion?
0 REPLIES 0
Message 1 of 1
428 Views, 0 Replies
I am new to maya fluid, and I have been trying to create a gasoline explosion. Unforunately I have run across a few problems. The first problem is getting the explosion to go outward. The fluids keep trying to go up rather than out. I mess with the temperature pressure/pressure threshold, but then my explosion breaks. What settings should I use to get my explosion to go outward? My other problem, is that when I turn up the the base resolution to 200 for my playbast tests, the fluid flattens at the top of the container even though I'm using auto resize. It doesn't flatten when the resolution is under 100. It almost seems the auto resize is not fast enough to keep up with the explosion at high base resolutions. Any help would be greatly appreciated.
0 REPLIES 0
