07:51 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm working with XGen IGS. I want to use a noise map as a modifier mask, then invert it and use the inverse as a mask on a different modifier. That way I can clump some hairs, then add a different modifier to the un-clumped hairs. I can run the map through a reverse node into a shader and it works just fine. If I run the reverse output into an xgen mask it doesn't work. Any help?
thx
