dirt dust when feet contacts ground
stevenfila7
Message 1 of 8
stevenfila7
Good day all,
 Is there a quick way to show dust when a character's feet are walking or hitting the ground?  I saw only one quick tutorial on youtube and it does not explain things clearly.
Any ideas?  If so, please supply screen shots or a quick video tutorial because I do not understand dynamics or text in explanations.  Thank you!
Please advise and best-
Replies (7)
Message 2 of 8
sean.heasley
Hi @stevenfila7
There's no quick and easy way to do this in Maya and/or a game engine.
This would need a particle effect to be made for the dust and then it would need to be linked to generate each time a characters foot lands.
Are you trying to do this only in Maya or in another program?
Message 3 of 8
stevenfila7
Hey Sean,
Absolutely, I wanted to do this in Maya but the only thing that I found is constant expressions.  There was only one video tutorial showing this and it is painstakingly hard to understand.
Any ideas?  I know the video tut shows it but I was looking for an easier approach then writing many expressions in which I have no experience with.
Thanks for getting back
Message 4 of 8
sean.heasley
Hi @stevenfila7
It's a bit old, but I would recommend this tutorial and then simply change the effect, timing to match a characters feet.
Message 5 of 8
sean.heasley
Hi @stevenfila7
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 6 of 8
stevenfila7
Hi Sean,
Sorry for the delayed response.  Apologies.
Anyhow, it help somewhat but would I have to make an emitter for every foot when the character is walking (animated).  If so that would be intense.
Is there a way to make the feet collide with the ground and create dust?  I only found that one tutorial and it was difficult to understand due to a large amount of expression writing.
Steve
Message 7 of 8
sean.heasley
Hi @stevenfila7
 It may be tough to understand due to language barriers but this tutorial should help!
Message 8 of 8
stevenfila7
yup that's the one that I found! hahaha.  thanks.
lots of expressions but I guess this is my best option.
thank you Sean!
