- Mute
- Permalink
- Report
im getting this error in xgen Maya 2018 or 2017 . There is a similar post but none of the solutions apply here
Error: line 1: XGen: Failed to find description0004a/groom/region/wool04.ptx
(Part of path doesn't exist)
If I create a sphere and generate a new description works OK, and with more of the geometry. But when the model has skin or in other cases appear this error.
I don't have spaces in paths and I created multiple new project folder test starting from scratch with simple files.
This is only a example but tried with numerous files and project folders with similar error
Wool04 is the name of the mesh. That path doesnt really exist, I would guess it should be generated automatically by Maya. Even if I create manually some of the paths and place a dummy ptx in that path doesn't work
// Error: line 1: XGen: Failed to find description0004a/groom/width/wool04.ptx //
// Error: line 1: XGen: Searched path includes:
C:/Users/Bia/Documents/maya/projects/default/xgen/collections/collection0004/description0004a/groom/width/wool04.ptx (Part of path doesn't exist)
C:/Users/Bia/Documents/xgen/description0004a/groom/width/wool04.ptx (Part of path doesn't exist)
C:/Program Files/Autodesk/Maya2017/plug-ins/xgen/presets/description0004a/groom/width/wool04.ptx (Part of path doesn't exist) //
// Error: line 1: XGen: Failed to find description0004a/groom/region/wool04.ptx //
C:/Users/Bia/Documents/maya/projects/default/xgen/collections/collection0004/description0004a/groom/region/wool04.ptx (Part of path doesn't exist)
C:/Users/Bia/Documents/xgen/description0004a/groom/region/wool04.ptx (Part of path doesn't exist)
C:/Program Files/Autodesk/Maya2017/plug-ins/xgen/presets/description0004a/groom/region/wool04.ptx (Part of path doesn't exist) //
