rigid body and gravity problems
Hi, I am trying to create an old fashioned bingo wheel with bingo balls rolling inside, I wanted the balls for move freely so tried to use active and passive rigid bodies and gravity but the balls fall through the wheel when the wheel has a passive rigid body. Is there anyway round this, or an alternative was of doing this?
francesco.torchia
Hi @Anonymous!
Would it be possible to share your scene file with me, so that I can take a look at it?
If the file is to big for the  forum or you don't want to share it publicly, seend me a private message and I will create a private shared folder for you.
Francesco Torchia
Technical Support Specialist – M&E (3ds Max, Maya)
Hi!
Sure here it is- I have since removed the rigid bodies as it keeps causing Maya to crash...
Sorry it wont attach the file
francesco.torchia
Hi again @Anonymous!
Send me a private message and I will create a private shared folder for you.
Francesco Torchia
To get around this I ended up using nCloth and passive colliders rather than rigid bodies.
francesco.torchia
Hi @Anonymous!
I believe that the cause of the issue is not the use of rigid bodies, because the scene you sent me worked perfectly on my computer, without adding or removing anything.
I would rather suppose that some corrupted preferences on your machine trigger a crash when rigid bodies are used.
Francesco Torchia
