Hi!
Running into an annoying issue. I have a really heavy simulation scene I want to cache to disk, but I can only make it about 50 frames through a cache to disk before Maya crashes. So what I need to do is to cache up to frame 50, and then restart maya and continue caching from frame 51 to 100, etc.
It seems like this should be possible given the controls available - but every time I try it the simulation just caches 1-50 again (but names it 51-100).
I have now tried everything everything I can think of; overlapping one start frame, overlapping several start frames. It just doesn't work.
It does the same crash after 50-ish frames on several computers, so I have no hope of being able to cache the whole thing at once. I really need to be able to append the cache. That's the only way.
Is this a known issue? Any fix available in that case? 😞 I have the latest SP.
Would really appreciate any advice!
Nicklas
