How to apply Color Expressions to Xgen Shader
oiver55
oiver55
Hello there Any help would be greatly appreciated. I made some color controls based off of the Bear Preset in Xgen. I just copied them over to my project. In the preset version when I change the colors using the expressions color picker it shows on the model in the viewport and it renders out the same. But when I try it on my project it changes the color in viewport but does not render the same color. Instead it is just rendering the xgen_Physical shader that is attached to it without the expression colors. In the Xgen Bear preset version I notice that the Xgen_Physical shader still has an effect on the over look of the fur. How can I set mine up to work that way? Thank you for your time.
Here are some videos to give you a better idea about the situation:
Michael_Todd
XGen Hair and Custom Color Expressions
Render Hair Workflow Example
Michael Todd
XGen Product Owner and Designer
