Gravity Issues
Gravity Issues
Gravity Issues
I'm trying to make a dice fall to a plane under the effect of gravity and collision. I've managed to recreate the effect that I want but it only seems to work once. Even if I begin the animation from the start, it doesn't happen again. I've made the dice an active rigid body (default settings) and the plane below it a passive rigid body (default settings) and applied gravity to only the dice (default settings). In need of some urgent help, thanks!
mspeer
Hi!
Please upload a scene-file.
Do a quick check - the simulation start frame in bullet? or nucleus? is the same as your timeline?
If you rewind (be kind) your simulation it should return to the initial state.  If it doesn't then the simulation start frame and the timeline (start frame) probably does not match.
C
