Freeze bitfrost simulation to render as a still frame
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, i'm a total bitfrost noob. I used the default cigarettesmoke bitfrost simulation in the browser. I wanna render a still frame at the 10th frame let's say. How can I "freeze" the simulation and render it as is ?
- I've tried tutorial with the file_cache node below, but it creates .bob file, and I have no idea what to do with it. My timeline is also yellow, so it doesn't seem like caching works here (I tried changing cache option in my preference such as flush the cache, increase ram but it's still yellow)
- I've seen people talk about bitfrost to mesh, but I cannot find this option at all in the attribute editor.
- Freezing transformation moves my simulation to the center point and rotate it (I moved it and rotate it to place it where I'd like to)
- I've tried bitfrost fluids -> compute and cache to disk but i get an error saying "Must select Bifrost containers to cache the data." In my outliner I only have the cigarettesmoke seen here
- I did a render making sure to select the 1 to 10 frame in the render settings, it seems that this work, but not possible as rendering 10frame with final quality would be way too long Below is my arnold render view at the 10th frame
AOV it exports (emission, volume, volume_albedo, volume direct, volume opacity, volume z)
looks like this which i think is correct (below is emission, ((I used emission)))
As you can see i'm total beginner in this, hopefully I explained somehow correctly. Thanks!
