(curve to spline add modifier) interactive groom editor, how to increase destin
mtripathi
Observer Observer
mtripathi
Observer
Observer
(curve to spline add modifier) interactive groom editor, how to  increase destiny of hair
sean.heasley
Hi @mtripathi and welcome to the community!
If you're using IGS then after the curves are converted you should be able to use the Density Brush.
If you aren't using IGS then you would need to use a Density Mask.
You can read up more on controlling density in Maya here!
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
sean.heasley
Hi @mtripathi
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
