Cloth simulation
Cloth simulation
Cloth simulation
Hello! Can anybody help me with simulation of maya cloth, I want the cloth to simulate as it is in the video below
please help!
https://www.youtube.com/watch?v=1C_40B9m4tI
damaggio
You can find a good way to start at digital tutors or Lynda .com , they cover all aspects of the Maya ncloth system.
slange
I would recommend setting up the primary motion with animation.
Then use a dynamic curve and use the hair system turbulence. To add a dynamic motion to cover up the basic animation.
Finally drive the cloth with the curve simulation. With pfxHair that is convert to mesh.
To add the subtle cloth motion on top.
This will give you art directable cloth with enough layers of dynamics to keep you sain.
I made a simple example For you to check out.
An important note is that the hairsystem uses it's own nucleus.
The pfxhair has a brush attached to make the mesh output flat.. instead of a tube.
the pfx mesh directly connected to cloth inMesh
Have fun
Scott
Hi
Thank you for the direct solution. Smiley Happy
