Bullet question
Bullet question
mgr0704
Bullet question
mgr0704
Trying to learn Bullet from online tutorials, and I can't seem to find the answer I am looking for. When you set up a simulation using cubes, everything works as you would expect. Hit play and the blocks fall with gravity as expected, but if you take a cube and shatter it with the Shatter Effect Option then make them an active rigid body in bullet, instead of just falling with gravity, they explode apart. I am trying to see if I can use Bullet to make the side of a building collapse downward as if shaken by an earthquake. Any idea of how to make these individual shattered pieces behave this way? Thanks.
Kahylan
Hi!
Sounds like your object is colliding with itself. Which is most likely an inexact collision shape type or a too big collison shape margin. Here is a tutorial that explains it pretty good:
https://www.youtube.com/watch?v=ewB8xuP4efI
I hope it helps!
mgr0704
Hi, yes that works, but shattering walls into glass-like shard pieces is not very realistic. So Bullet dynamics will  not work if the wall is shattered using edge jagginess?
