Bullet alternative?
Bullet alternative?
Parmenides
Bullet alternative?
Parmenides
I always seem to have issues with jitter with Bullet. I have searched and others have the same issue but no real solution. Active rigid bodies don't stop after they should. There is a "rest at beginning" but there should be a rest after main contact or something.  Sometimes they come to a complete stop and then start again seconds later. Not very similar to the real world. Large object fare better but many small falling pieces are unmanageable. I have raised the 'Internal Fixed Frame Rate' to the max, and raised the 'Max Num Iterations' as well but no success.  What other tools are there or is just a flaw in Bullet?
My current project is a bunch of small flakes that come down and stack efficiently (ie; not landing vertically on their edge) in layers. Can someone suggest something better to use?   Thanks.   -Derryl
sepu6
Bullet is well known for those issues, jitter, and so on and not just in Maya, In Houdini as well, so the best way to deal with those in Maya is doing through Mash as of right now, so you can blend your dynamics and Mash position/rotations.
Parmenides
Thanks Sepu. Can you point me to something that explains this blend that you are talking about? I am pretty familiar with Mash. That is where I started with this but couldn't remove the jitters.
sepu6
You probably will need 2 Mash Networks for that work so blending between the final pos (Time frozen/ rest pos) and the sim, Then you can use falloffs to blend between the jitter pieces and the ones that are not seamless. Using the Merge node
Parmenides
I ended up creating the layers in final form and playing them backwards by using Dash and the ts(number) command. Worked great. Plays back super fast when there is no physics involved.
