Rendered layout too dark
patpinkston5FJ9C
Message 1 of 9
patpinkston5FJ9C
I'm a new user and I'm stuck.  I've finished my rendered character.  I have a HDRI image on my SkyDomeLight of deep space (so it must be dark out there).  I have spotLights on my character and I've turned up the cone angle, intesity, messed with the penumbra angle.... no matter what I do, my character remains in a dimly lit area (and the deep space outside my "craft") gets brighter and brighter.  I know I'm missing something but I don't know what.
My goal is to have my character lit up (inside the "craft") and the HDRI space image, to remain dark....like space is supposed to be.  The first one below is what it should look like and the second is what's happening. What is should look likeWhat is should look likeUnfortunately, what it is in realityUnfortunately, what it is in reality
Replies (8)
Message 2 of 9
mspeer
Hi!
Please provide a Maya scene-file.
Message 3 of 9
patpinkston5FJ9C
I can't attach the document.  It keeps being rejected by the forum program as unknown.
Message 4 of 9
mspeer
Hi!
Please ZIP the date before the upload.
You can also upload the data anywhere else and provide a download link.
Message 5 of 9
patpinkston5FJ9C
Anyone willing to help I've attached the scene file as a Zip file.  Please open and get me out of my hell.  🙂
Message 6 of 9
patpinkston5FJ9C
I've uploaded the zip file.
Message 7 of 9
mspeer
Hi!
Thanks for the file.
The intensity values for the lights are just way too low.
Please try "1000" or higher for Intensity or increase the values for Exposure (you can manually enter values besides the slider range.)
(The reason for the need of such high values is the large scene scale and the "small" light source.)
Tip:
If you want to send a notification for a person in a message, please choose the term (at), like @patpinkston5FJ9C .
Message 8 of 9
patpinkston5FJ9C
YOU ARE AWESOME!!!!  Thank you SOOOOO MUCH!!!
Message 9 of 9
animatewithabhay
The core problem
  • Sky Dome Light = global light source
  • HDRI = both illumination + background
  • Increasing exposure affects everything
  • Space HDRIs are visually dark, but still emit light
So Arnold is doing exactly what it’s designed to do.
The correct professional fix (best practice) 1. Separate lighting from background (MOST IMPORTANT)
In the Sky Dome Light settings:
  • Set Camera = ON
  • Set Diffuse = 0
  • Set Specular = 0
This makes the HDRI:
  • Visible to the camera
  • Invisible to scene lighting
Now your space stays dark and stops affecting exposure.
2. Light the character with local lights only
Use:
  • Area Lights
  • Spot Lights
  • Key / Fill / Rim setup inside the craft
Increase intensity freely — the HDRI will no longer brighten.
Tip: Area Lights usually look more natural than Spot Lights for interiors.
3. Check camera exposure (often overlooked)
In the Arnold Camera settings:
  • Lower Exposure
  • Or reset it to 0 while lighting
Many beginners accidentally fight the camera instead of the lights.
4. Optional: Use light linking (advanced but clean)
You can also:
  • Exclude the Sky Dome Light from affecting the character
  • Keep it only for reflections or background
This is common in cinematic lighting.
Why your “space” looks wrong
HDRI space maps often contain:
  • Bright stars
  • Nebula highlights
  • High dynamic range values
They look dark, but still emit light unless restricted.
