When I export an alembic, the UVs are moving.
It is possible pour freeze the UVs position and keeping animation? Because, delete non deformer history fix the UVs position but delete my alembic animation.
Maxime
Solved by alec.andersenLP8AU. Go to Solution.
hello @Anonymous,
In your alembic export, did you check off 'UV Write' and 'Write UV sets'? Including these options, the alembic system is not optimized for UV stability; if you are far along in the UV process I would not recommend exporting.
I hope this helps your situation!
Hello @Anonymous,
Is this a helpful response? I look forward to hearing from you!
