Hi there,
I am currently working on an animation for a student project in the latest Maya 2018.2
Just recently I have been working in the graph editor during my Linear pass stage, although I have run into issues involving my undo command.
When I am editing keys in the Graph Editor and have to undo an action, all of a sudden I cant undo anything.
I get no warning message about the queue being turned off because it isn't, and I have my undo history set to infinite.
In my script editor, it is seeing that I am trying to undo, but nothing happens!
Sometimes it seems to work if I alt-click in my view port and just hit Z. Other times I have to click back into the graph editor and only sometimes does it start undoing my actions.
I cannot figure out why its doing this (is it a bug?) and its super stressful since every action I do in the graph editor cannot be undone.
I hope someone can figure out why this is happening,
Thank you
Solved by mspeer. Go to Solution.
Been playing with settings a bit more, I've had 'Show buffer curves' enabled, which seems to have caused this issue.
This is really odd since I haven't had this issue before with buffer curves enabled.
UPDATE:
So it manages to eventually work, after I hit Ctrl - Z a million times.
This is what the script editor looks like, what the hell?:
// 1 // currentTime 185 ; selectKey -clear ; selectKey -add -k -t 185 LeftLeg_IK_Leg_rotateY ; cutKey -animation keys -clear; // 0 // currentTime 186 ; // Undo: currentTime // Undo: Undo // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: // Undo: cutKey // Undo: selectKey currentTime 175 ; currentTime 186 ; selectKey -clear ; selectKey -add -k -t 186 LeftLeg_IK_Leg_translateX ; selectKey -add -k -t 186 LeftLeg_IK_Leg_translateY ; selectKey -add -k -t 186 LeftLeg_IK_Leg_translateZ ; cutKey -animation keys -clear;
Happened to me just now, can;t undo keys. I am getting empty undo command :<
Turns out my issue came from the Long Winter animation rigs. (http://longwintermembers.com/)
Not sure if this problem was ever fixed since I stopped using the rigs after this issue which I in turn stopped getting this undo bug.
