I'm trying to edit face animation done with blendshapes at time editor.
So I'm selecting the object and adding it as a clip. Next, I try to cut some parts or adjust the animation and nothing seem to happen.
Please see the video attached.
I'm using Maya 2023.
Solved by minas.aslanyan. Go to Solution.
I didn't see any animation in the channels in your hidden geometry. The shape animation is located at the blendshape node in the head
Doesn't seem to work, when adding from the blend shape editor, animation just disappears.
