the control rig is frozen
markkent61
markkent61
my tools do not work i am trying to animate the effectors on a model
Replies (8)
gautham.chandran47
This could be because effector is controlled by something else. Select the head effector and go to channel box, if there is any connection going on you should be able to see that there. You could post that screenshot or share the file if that's possible for further assistance.qwe.PNG
Goutham Chandran
Cinematic Animator | Rockstar Games
Linkedin | Instagram | Facebook
markkent61
thanks for the reply
i can not manipulate any rigs so i must have turned something on or off
gautham.chandran47
Seems you're using an HIK rig. Would you show your control rig setup?
Goutham Chandran
markkent61
is this what you mean
gautham.chandran47
As I suspected, the selection is currently on "selection". In this mode, you cannot manipulate any controller/effector if it's not IK. You can change the selection to "body part" which is just left to that and that should fix it.
Goutham Chandran
markkent61
changing the selection to "body part" was the fix  .
 thanks
Hello!
Can you give me the solution below the image why control rig option is disable i search many time in google for the solution but i can not find the solution please tell me the solution if you know?
i think any tool of maya is not install in my system otherwise if you know the problem then give me the solution.
rogodoy
Just enable IK Blend if it is 0.00 make it 1.00.
