Hello all,
So I probably did something, but I don't know what.. Maybe some of you know how to undo it and if not; I'll find it out and I allready found a workaround.. But it would be easier to just solve the issue 😄
When I select the parent of the leg, then he doesn't highlight the other parts of the leg ( like he used to do) and in the channel box there also doesn't show up a setting with translation. And the keyframes also don't show up in the time editor.
I added to pictures. In one you can see the problem and in the other one, you'll see that other parts work fine. Hope you can help!
