Rig Shrinks Upon Opening File
So I've been having this bizarre issue with Maya--I open up a file with a rig (that's been skinned to a character mesh) and after a few seconds, the rig shrinks back to it's default size. Have you guys ever run into this problem? I've attached a video to show you what I mean.
I've encountered this issue in the past, and previously I've been able to fix it simply by updating Maya...no dice this time, however. I even rigged the character again just to see if starting over would do the trick, but nope! I just wanted to reach out in case you possibly knew a solution. Searching the web has been pretty fruitless thus far.
trs_andre
It seems to be selecting the head out of nowhere... Do you have any idea why? Any script you might be using, etc.
André Moreira
Game Developer / Technical Artist
LinkedIn
Not that I know of. I sent the file off to someone to take a look at and they had no issue (yay), so I think this is just a problem with my own laptop (sad). Fortunately, I have another one to try the file on shortly.
trs_andre
I see...
Optimizing the scene through the file menu or putting everything in a new one doesn't solve it?
You might also try to make a copy of the weighted skin, and try to reattach it clean.
Hope it helps!
André Moreira
LinkedIn
