So weird enough, 2024 works fine but anything 2023 and under I get this error. Tried everything in this post https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Autodesk-360-Reque... and nothing fixed it. I need 2022 for a specific project, all help is much appreciated
Solved by Benjamin_oldfield. Go to Solution.
I see that im having some sort of issue with my personal computer sending a signal to the autodesk servers if this helps anybody. It doesnt make sense though because I can access 2024 still even when logging out and trying to force the same issue.
