Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
recordAttr in maya2019
11 REPLIES 11
Message 1 of 12
966 Views, 11 Replies
I can get the recordAttr to work fine in 2018 but not in 2019. Anyone else?
11 REPLIES 11
Message 2 of 12
alec.andersenLP8AU
Hello @Anonymous,
Would you be able to provide a sample use that is not working in 2019? I did a quick test and I am getting the same results as in 2018. I'm happy to assist further and look forward to hearing from you!
Message 3 of 12
in reply to: alec.andersenLP8AU
I'm running Maya2019.
Viewport2.0.
Play every frame in 24 fps
I run this in Mel:
recordAttr -at "translate";
play - rec;
In 2019 it starts recording but I can't stop it and it only records the first frame. With the same settings in 2018.4 I can stop it fine and it records on multiple keys.
Message 4 of 12
alec.andersenLP8AU
Hello @Anonymous,
Thank you for the additional clarification, I was able to reproduce this issue and this has been reported to the development team!
Thank you again for pointing this out and helping us improve Maya!
Message 5 of 12
any ETA?
Message 6 of 12
alec.andersenLP8AU
Hello @Anonymous,
This has actually already been grabbed by the development team, so they are presently looking at a resolution. That being said, I do not know which iteration of Maya 2019 will see this issue resolved. It may also be possible that it is saved for resolution in Maya 2020, though I think this is less likely. We'll be able to better approximate resolution as time passes, so I encourage you to check in at a later date as well. 🙂
For now though, I'd encourage you to use Maya 2018 when utilizing the recordAttr function.
Message 7 of 12
I wanted to check in on this update for recordAttr in Maya 2019. Any progress?
Thank you!
Message 8 of 12
heya,
Just wanted to check if there was any progress on this too?
Cheers!
Message 9 of 12
now trying to use recordAttr just crashes Maya 2020 entirely. This is so depressing, all the money that goes into Maya and the software is actually regressing.
Message 10 of 12
emilp
Why is this marked as "Solved"??
Message 11 of 12
emilp
In case anyone needs this for recording external data streams coming in using commandPort, one easy solution is to send a setKeyframe after each setAttr from the external source. Then just hit play and it will record.
Message 12 of 12
in reply to: emilp
Sorry Emil but could you elaborate on that solution?!
