I did an animation for the aang model provided by Agora studios and wasn't able to export it in FBX. the animation disappears. Please tell me what to do!
Solved by hamsterHamster. Go to Solution.
Make sure you're selecting the correct objects (geometry, joints), or just do export all. Personally I prefer using the game exporter for exporting FBX's. It's found under file, and if it's not there you need to load it in your plugin manager.
Don't forget to mark the Animation in the FBX export options.
Test on less complex scene, like animate a sphere.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the ACCEPT SOLUTION button, so others might find it much more easily.
