Maya Freezes when Painting Skin Weights
Hi all, Maya (2020) keeps locking up/freezing on me when painting skin weights. I get no notification that Maya has crashed, the screen will just lock up (sometimes flicker) and I still have control of the cursor, but I am unable to do anything in Maya from this point and have to open the windows task master to close the program so I can reopen it and continue working. I've tried changing the evaluation mode to DG as I saw reccomended in a similar thread but have had no luck. I've been saving fairly often to avoid losing progress, but the consitent locking up is frustrating.
Any help would be greatfully appreciated. 😊
kelly_hynes
Hard for me to know what is happening based on your description.  Do you eventually crash?  If yes, could you send a CER report number.  Is there any info in the output window?
One thing to try - Disable GPU override.   To do this, go in Windows < General Editors < Evaluation toolkit, and in the section entitled 01) Modes - uncheck GPU Override.
Let me know if this helps.
Kelly
Kelly Hynes
Manager, Software QA Engineering
Installation & Licensing forums | Contact product support | Autodesk AREA
Hi thank you for your reply!
Maya doesn't seem to eventually crash, it just freezes. I can still move the cursor around, but I cannot interact with anything. I tried disabling the GPU overide, this looked like it was working for a while but Maya evenutally froze again whilst painting skin weights. It did feel less frequent with the GPU overide disabled. Here's a copy of what was in the outlook window when it froze.
Initialized VP2.0 renderer {
Version : 2016.11.53.12. Feature Level 5.
Adapter : GeForce GTX 1050/PCIe/SSE2
Vendor ID: 4318. Device ID : 16027
Driver : .
API : OpenGL V.4.6.
Max texture size : 16384 * 16384.
Max tex coords : 32
Shader versions supported (Vertex: 5, Geometry: 5, Pixel 5).
Shader compiler profile : (Best card profile)
Active stereo support available : 0
GPU Memory Limit : 4096 MB.
CPU Memory Limit: 7638.12 MB.
MultiDraw consolidation: enabled
OpenCL evaluator is attempting to initialize OpenCL.
Detected 2 OpenCL Platforms:
0: NVIDIA Corporation. NVIDIA CUDA. OpenCL 1.2 CUDA 11.1.114.
Supported extensions: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts cl_nv_create_buffer cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_device_uuid
1: Intel(R) Corporation. Intel(R) OpenCL HD Graphics. OpenCL 2.1 .
OpenCL evaluator choosing OpenCL platform NVIDIA Corporation.
Choosing OpenCL Device GeForce GTX 1050. Device Type: GPU Device is available.
00:00:01 1217MB | log started Wed Jan 27 14:01:09 2021
00:00:01 1217MB | Arnold 6.0.4.0 [3fad32b9] windows icc-17.0.2 oiio-2.2.1 osl-1.11.6 vdb-4.0.0 clm-1.1.1.118 rlm-12.4.2 optix-6.6.0 2020/07/31 08:11:38
00:00:01 1217MB | running on DESKTOP-9K41LL1, pid=12796
00:00:01 1217MB | 1 x Intel(R) Core(TM) i5-8300H CPU @ 2.30GHz (4 cores, 8 logical) with 8040MB
00:00:01 1217MB | NVIDIA driver version 457.20 (Optix 60700)
00:00:01 1217MB | GPU 0: GeForce GTX 1050 @ 1493MHz (compute 6.1) with 4096MB (3910MB available) (NVLink:0)
00:00:01 1217MB |
00:00:01 1217MB | soft limit for open files raised from 512 to 2048
00:00:01 1217MB |
00:00:01 1217MB | loading plugins from C:\Program Files\Autodesk\Arnold\maya2020\bin\..\plugins ...
00:00:01 1217MB | alembic_proc.dll: alembic uses Arnold 6.0.4.0
00:00:01 1217MB | cryptomatte.dll: cryptomatte uses Arnold 6.0.4.0
00:00:01 1217MB | cryptomatte.dll: cryptomatte_filter uses Arnold 6.0.4.0
00:00:01 1217MB | cryptomatte.dll: cryptomatte_manifest_driver uses Arnold 6.0.4.0
00:00:01 1217MB | synColor_shaders.dll: color_manager_syncolor uses Arnold 6.0.4.0
00:00:01 1234MB | usd_proc.dll: usd uses Arnold 6.0.4.0
00:00:01 1234MB | loaded 6 plugins from 4 lib(s) in 0:00.53
Thanks for your help.
kelly_hynes
Quick question:  Are you painting skin weights on blendshapes?  There is an existing defect with painting skin weights on blendshapes.
Kelly
Kelly Hynes
Not blendshapes, just the regular model. I'm not sure if this is any help but I do have it a few controlers key framed on the timeline so I can check for the deformations.
Thanks for your help so far.
RichSuchy
Having the same problem. Sorry, I can't help, but as it doesn't eventually crash I can't send info to Autodesk- Just posting to raise it to it's not just your file.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
