Hello, there are several ways to do that in Mash.
An explode node might not be the best solution since it breaks every face of your geometry, and assigns a Mash point to each face, so you will end up with millions of faces.
You should prepare your geometry with all of your buildings separated and clean with centered pivots.
you can select them all and put them into a Mash setup. (If the buildings are really a lot, you can think of layering your setup in areas, and build the effect one area at the time.)
once you have the Mash setup, go to the Distribute node and change to distribution type into "initial State"
This way the Mash point will snap to the initial state of your buildings.
Now you need an id node to assign each point to your different buildings.
You should see now a reproduction of your city as a
Mash setup.
Now you can add an offset node for example and animate the scaleY.
If you animate the random strength attribute of the offset node, your buildings should randomly grow from o to the actual size.
If you want, as you said, some sort of wave as a growing motion, you have to solve a little problem:
This comes from the fact that your buildings do not have world transformations values.
Their transformations are frozen with default values and Mash will consider only the pivot point at the center of the world for all of them.
This means that if you create a texture or a falloff object for the weight of the offset node, it won´t work as you expect.
To work properly, Mash needs to know each world transformation of every building and this means that you need a trick to bake the world transformations to your buildings.
For this I wrote a simple script:
string $selection[] = `ls -sl`;
string $tempConst = "temp";
for ($obj in $selection)
string $loc[] = `spaceLocator`;
pointConstraint -offset 0 0 0 -n $tempConst -weight 1 $obj $loc[0];
delete $tempConst;
parent $obj $loc[0];
makeIdentity -apply true -t 1 -n 0 -pn 1 $obj;
parent -w $obj;
delete $loc[0];
If you select your buildings and run this script, every building will get world transformations values,
After that, you can redo the previous steps of the Mash setup and you will be free to map textures on Strength values and add falloff objects.
I attached two examples, one with the first simple method, the second after baking the global values.
Cheers,
D
