Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
Issue exporting deformations to fbx
6 REPLIES 6
kolin0806
788 Views, 6 Replies
I have an issue on maya 2023 with exporting deformations to fbx
Heard there is a new system to deformation on maya and i dont understand it
I cant export any deformations to fbx formats
i need it for unity
6 REPLIES 6
teddude75
in reply to: kolin0806
You can export a fbx with joints, skin deformation, and blendshapes that's it. You can bake your deformers like delta mush in the weights of the skinned mesh. When you export an fbx, select the mesh and joints and in the options select animation, blendshapes, skins, and shape attributes. If you have a mesh that is with out a skeleton, you can export an Alembic. Unity will import alembic.
teddude75
kolin0806
in reply to: teddude75
Thank you so much for the help, unfortunately i still couldn’t resolve the issue. Do you mind coming up on a call with me real quick so i could share my screen with you and get your feedback?
teddude75
do you have a skeleton? What deformer are you talking about?
kolin0806
teddude75
If you set keys on the joints you can export an animation. It won't move either wise. I should export fine. Select the cylinder and skeleton only and export as an fbx.
