Goal: I am trying to copy rotation of some joint to another, in this case Joint1 to Joint2, and then add rotation from another object, in this case Box2, to Joint2, on top of the initial copy rotation, as shown in the screenshot below. That's all.
Current result: So far I'm able to do only one of those, but not both of them at the same time, as Maya does not allow for a single object to have multiple Orient constraints, and multiple Parent constraints get blended at all times.
Question: Is it possible in Maya in any way to copy rotation from Object A to Object B, then also copy another rotation from Object C to Object B, on top of the existing, copied rotation?
Genesis of the problem: This scene is a demonstration of a principle that allows to take any video game character model with an armature (which is usually FK-only, thus useless for animation), create an automatic IK/FK rig that has a similar bone setup, constrain both rigs to each other, and then use the IK/FK rig to animate the game armature, and thus the character. I'm trying to see if this principle can be done in any 3D software other than Blender.
Think of Suzanne1 and Joint1 in the picture as a body part of a character model, e.g. an arm, and a bone controlling it, and Joint2 as the bone of the said IK/FK rig that's supposed to control it. If I make some automatic IK/FK character rig through some autorigging system like Blender's Rigify, the bones in the rig will have differing axis orientations from the game rig - so if I copy the rotations from the game rig to the IK/FK rig, the meshes will face the wrong direction, as shown in the screenshot above.
This can be fixed by adding rotation from another object, which will compensate for the wrong direction, as demonstrated in Blender screenshots below:
The above screenshot is also the result I'm trying to achieve in Maya.
Additional notes:
Solved by Kahylan. Go to Solution.
Hi!
I'm sorry if this is a stupid question and I'm not quite understanding the problem here.
But why aren't you just using the "Maintain Offset" option in your parent or orient constraint? That way even if your game rig is in a different orientation, Maya will automatically calculate the offset needed so you game rig follows your IK/FK rig in space.
if you use some shading node like "plus-minus-average" and do some connections in the node editor, you can add as many attributes as you want and pipe the result into one object´s attribute...
@dinofigueraI've tried plusMinAvg but I've failed to make a combination that would give me the result I need.
@Kahylan For some reason, I've actually dismissed and incorrectly tested that option and it indeed is what I needed - my bad 😅
While for the most part this does solve the problem for me, I think the question I've asked initially might still stand as someone later might ask themselves the same question but for different reasons. So if anybody knows the answer, it will be appreciated.
There's one more thing I wanted to do - I have some rotation animation stored in joint1, and I want to transfer it to joint2 in a way so it's visually identical on the monkeys (i.e. they face the same direction). Maintain offset already solves the direction problem, so all I would need is to key the constrained rotation attributes.
However, that causes to create a pairBlend node which blends the animation on the object with the animation from the parent and the one I've just created. That way I can copy just a single keyframe, and any other keyframes I have to manually copypaste as shown in the screenshots below (which is fine for what I need, but completely impractical if I wanted to do apply it in practice)
Is there any way to key constrained (blue) attributes?
You don't want to key the attributes.. Pair blend . "blends" between keys and constraint.
you want to "add" an offset, just as your maintain offset did when you created the constraint.
You'll notice that the constraint has values in the offset channels
or. just put a group node between the constrained object. and whatever is below it
so in your case I would
parent the joint to itself.
make the constraint control that parent
then animate the joint for the offset
of make a basic rig control group so you have something to easily select that's not a joint. and then the joint can be an additional offset, or free
-=s
