Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
Image sequence problems in material
6 REPLIES 6
5063 Views, 6 Replies
I`m having problems with materials when I set "image sequence" in the file slot.
The image loads perfectly, but when I enable "image sequence" the image vanishes. The same for Image planes.
I've tried some formats and compressions exportations in After Effects, but none works.
The interesting part: we work with facial mocap capture, and the software (Faceware Analyser) exports any video in image sequences. When I export using Faceware Analyser, Maya reads perfectly the "image sequence" resource.
Could that be some problem with After Effects?
6 REPLIES 6
mspeer
Hi!
Check the sequence format, for example try frame.001.png instead of frame001.png.
Is there a difference in naming between your Mocap and After Effects sequences?
in reply to: mspeer
I checked this before, because in some bug report in Maya 2015, this was a issue.
But yes, the frames from mocap and AfterEffects has the same non-alphanumeric characters (underscore, dots, etc)
mspeer
Hi!
Are you able to upload a part of the image sequence that doesn't work (3 frames should be enough).
Even 1 image should be enough, i can copy and rename the image.
in reply to: mspeer
I solved this mystery, but i`m still confused because the solution is meaningless for me.
I just shortened the file name size (The frame count had 5 decimal places, I cut down to 3)
Someone have any idea of the logic behind this?
Really strange but at least is working 🙂
Thanks for your attention and for your help mspeer (y)
mspeer
Hi!
It seems that if you don't use an additional "." as separator you have a limit of four digits like "filename0001.jpg"
If you add an additional "." you can have up to 5 digits like "filename.00001.jpg".
I can't find a note about this limitation, so please
report this problem (bug?) to Autodesk.
Help -> Speak Back -> Report a Problem
or
post a new Idea in the Ideas for Maya forum.
in reply to: mspeer
You can edit "C:\Program Files\Autodesk\Maya2018\scripts\others\getFileSequenceFormats.mel"
to extend the list of frame number padding formats that maya recognizes.
Place a copy in <user>/maya/2018/scripts/ to override the maya install copy.
Technology Administrators
