Hi. I keep searched this problem in forums but can't found a similar problem, so I'm posting it.
As the title says, IK spline is unstable with a degree 2 curve + more than 18 joints when stretch setting applied. degree 3 curve or fewer than 18 joints are fine. I tested this in Maya 2018 and 2022.5 and both are same.
Steps to make this problem:
- Make a joint chain with more than 18 joints.
- Create an IK spline with auto-create/simplify.
- Rebuild spline curve with degree 2.
- I also tried delete IK handle then rebuild curve and made IK spline again, but no difference.
- Apply stretch setting.
Here is a picture of my stretch setting. It's simple. I put the value that stretched curve length / original curve length * default joint translate X into joint translate X. I tried not translate X but scale X, there is no difference
![turboPP39M_0-1712296277411.png turboPP39M_0-1712296277411.png](/t5/image/serverpage/image-id/1346154iF0B847BC02A0E4CF/image-size/medium?v=v2&px=400)
