hello, I'm new to Maya and i have this question or problem, that I can't copy weight paint of SK_Manny to my new character, I really appreciate your comments
https://youtu.be/jRuFKv5WTrQ
Solved by stephenkmann. Go to Solution.
ok, so.. you need to keep the SK_manny skinned.
then. select all the same joints and bind your new character.
and THEN, you can select Manny first. and your new character second and use copy skin weights.
hth
-=s
I realized that, I saw some tutorials they were doing that and i thought the skin weight will stay after you unbind the armature. there isn't a single video tutorial about maya in my language. that's a big problem. but I can do it. I only want maya to add new modern UI. anddddddddddd. thank you so much my friend
