Hello, i have try to searching on this forum but didn't work. The problem it when i import the first FBX it work fine, but then i import the second it totaly replace animation in the first. I dont know how to make muti animation FBX import in maya. The file i download in mixamo website. Please help me, sr for my bad english
Exactly as mentioned above, use the Time Editor. You can just drag and drop each fbx from your folder to your time editor. Here's a great Autodesk tutorial that helped me lots when Time Editor was new to me: https://youtu.be/rV-xC3tz1rs
Hi, I am also having the same problem. The above response is great for some users but for me, because I am trying to use two separate characters in my scene at the same time. Please advise, thanks
