Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
How to control curve color using Node Editor
8 REPLIES 8
Message 1 of 9
gautham.chandran47
3477 Views, 8 Replies
Is there any way to control a curves color using node editor ? Smiley Frustrated
I know we can change the color using drawing overrides. But how to contol it ? Smiley Sad
My need is I want to make my controller change its color if its value is greater than zero. So it  makes a visual representation of the values I tweaked ( facial UI controls ) Smiley Very Happy
Goutham Chandran
Cinematic Animator | Rockstar Games
Linkedin | Instagram | Facebook
8 REPLIES 8
Message 2 of 9
Yes, it is possible to connect to attributes like the override color even though they are not visible by default.
The easiest way is to use MEL:
setAttr "myNURBSCurve.overrideEnabled" 1;
connectAttr myControlNode.outColor myNURBSCurve.overrideColorRGB
Then you get this:
You can also RMB on the node with the hidden attributes and "Show all Attributes":
... and then locate the attribute and connect:
Message 3 of 9
Thanks for the quick replay, Smiley Very Happy
It worked as you said, but unfortunately I couldn't change the color Smiley Embarassed
The "myControlNode" you mentioned is a layered texture ? Thats how I connected it.
If else would you please tell me which node is the "myControlNode" ?
Goutham Chandran
Message 4 of 9
I wouldn't take a texture node because how do you then control the color change?
For a rig with a certain condition to change the color an expression might be the right way.
This example would change the color of the nurbsCircle1 at frame 26:
if (frame>25) {
     nurbsCircle1.overrideColorR = 1;
     nurbsCircle1.overrideColorG = 0;
     nurbsCircle1.overrideColorB = 0;
} else {
     nurbsCircle1.overrideColorR = 0;
     nurbsCircle1.overrideColorB = 1;
You can't enter the expression editor from the Attribute Editor (like with most other attributes), you have to open it and create the expression from scratch.
Message 5 of 9
unfortunately if doesn't seems working. I now understand i should put a texture node to control curve color, but is there any other node we can use in this situation ? the script is giving me errors.
Goutham Chandran
Message 6 of 9
Yes, it won't work in the Script Editor.
This example works only in the Expression Editor:
Create a NURBS circle.
Set "Enable Overrides" ON and "Color" to "RGB"
and then in the Expression Editor:
Message 7 of 9
I did everything as you mentioned and the expressions didn't give any errors but I cant find the out put. The color is not changing.. Smiley Sad
Any idea why ?
Could you please post the work file for a reference maybe ?
I dont know what I'm doing wrong.
Goutham Chandran
Message 8 of 9
When i combined the both methods you mentioned it came out alive Smiley Very Happy...
Goutham Chandran
Message 9 of 9
Thanks a lot . as you mentioned I created a "layerd textured node" and curve and renamed it accordingly;
You were right about using a texture node to control curve color,
so I changed the "color" mode from "index" to "RGB" in the drawing overrides on attribute editor.
And after that I could easily change the color of the curve through the layered texture's properties.
I can even animate it.
Goutham Chandran
