- Mute
- Permalink
- Report
Hi!
I have a problem when I want to combine a autorig with HIK.
Really all woks fine except fingers. Here is the explanation of the process step by step:
- I was mapping all joints of my custom rig. (The validation status indicator was green)
- I modified the CustomRigControlsConfig.xml file to adjust the Controls character layout. I Added hands and Toes (I copied the code of RigControlsConfig.xml) and for fingers I created my own code.
Visually works fine, all controllers work fine except fingers (second and third phalanx).
In this cases (second and third phalanx) maya fails and don´t let me link a custom controller
This is the Error:
# Error: file: C:/Program Files/Autodesk/Maya2020/scripts/others/retargeter.mel line 588: TypeError: file <maya console> line 3: unbound method toGraph() must be called with DefaultRetargeter instance as first argument (got NoneType instance instead) #
I hope you can help me
Thanks for our time
