Help! Elbow / Knee Rig snapping/locking (right side problem)
danielblaze
danielblaze
Hi, I'm trying to create a stretchy IK leg with knee snapping/Locking. I managed to create the IK stretching on both the sides, however when i'm doing the knee snapping on the right side, the joints first squash and then they flip.
Why is this happening and how do I fix this please?
screenshots attached.
Your help is very much appreciated.
Daniel
sean.heasley
Hi @danielblaze
Does this only happen with the right side?
If so it may be because the ankle orientation is different than the left. If you look at your third screenshot the right ankle gizmo is pointing its X, Y and Z coordinates in the wrong direction compared to the rest of the joints. Then in your other screenshot when you get the issue the orientation is fixed and facing the right way.
So I would recommend you try redoing/fixing that joint and see if anything changes!
sean.heasley
Hi @danielblaze
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
danielblaze
What I actually ended up doing is using a multiplyDivide node to invert the values to negative on the right side and it worked fine 🙂
Thanks anyway.
sean.heasley
Hi @danielblaze
No problem! Glad you figure it out and thanks for explaining what you did to solve it! I went ahead and marked your post as the solution to this thread Smiley Happy.
