// Error: file: exportSkinMap.mel line 287: Failed to export the attribute map.
This widget could not be displayed.
Getting the following error when attempting to export a skin weights map.
// Error: file: /Applications/Autodesk/maya2019/Maya.app/Contents/scripts/others/exportSkinMap.mel line 287: Failed to export the attribute map.
Any help would be great.
Davey
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
Thanks for posting! Is this error happening with all scenes, or just a specific rig? Have you tried shutting down Maya and Resetting the Preferences to Default?
Thanks again for being a part of our community 🙂
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
I hope you had a good weekend! 🙂 I just wanted to check in and see how things were going. Any new developments with this case? Anything else I can help with?
Thanks again for being a part of our community!
Jordan Giboney
Hi Jordon,
The skin weights export oddly started working without a single crash - not entirely sure why, but it's working.
Davey
jaromir.stifter
Hello, I have just encountered the same error. It seems to be persistent through all the scenes but only within one project. Any idea why this could be?
