So I'm in the rigging process of the character regarding animation and whenever I bind the joints to the skin, I get an error message that there was a failure in computing weights. i don't know what went wrong but I'm in the process on trying to figure it it. If anyone has any solutions around this error, that would be extremely helpful.
I had the same error when skinning joints to a ik spline curve. When I looked in the script editor (the button to the right of the error message) I saw there was actually two errors:
"// Error: line 0: Current bind method does not work on non-poly objects. Please choose another method. //
// Error: line 0: Failed computing weights. // "
But only the last error was visible in the window. I changed the bind method to "closest in hierarchy" and that fixed the problem. I don´t know if you have the same problem, but maybe there is more information in the script editor that can help you solve it.
