How do I disable snapping in the graph editor so it behaves like the timeslider? I scale some keys so all the but first are on fractions of a key, I can then move them in the timeslider keeping their relative spacing intact. Doing the same in the graph editor they snap to the nearest whole frame. The only solution I've found was disabling grid snapping all together in the graph editor, but ideally I'd like to offset the select in whole frame increments, again just keeping the spacing of the keys exactly how the timeslider works. Thanks!
Solved by mcw0. Go to Solution.
It's all or nothing I'm afraid. Either you grid snap all of the keys or none of the keys. If it doesn't have to be interactive, you can use a small script. You can place it on the shelf and hit it a few times until you get the curve where you want it. Just set the increment value.
int $increment = 25;
keyframe -e -iub true -animation keys -r -o over -tc $increment ;
Have you tried going into your Time Slider settings and turning off the "Auto-Snap Keys" option box? If this is on, it will make all your keys in the Graph Editor snap to whole frames like the rule set for the Time Slider since they're at parity
