Current manipulator and active objects have no keyable attributes Error
Hi
I am trying to move Dana's rig controller and I get the error Warning: file: /Applications/Autodesk/maya2020/Maya.app/Contents/scripts/others/doSetKeyframeArgList.mel line 633: Current manipulator and active objects have no keyable attributes, or animation layers are present and the BaseAnimation bar is not selected or locked. //
What can I do?
Replies (12)
Hi
There is a root controller in my rig which has a blender option in its outputs (Channel Box) . This blender option is red and 0 by default. Whenever I try to alter its value e.g. 1, I get the error message "setAttr "Dana_Rig_v1_7:ScaleBlendRoot_M.blender" 1;
// Error: line 1: setAttr: The attribute 'Dana_Rig_v1_7:ScaleBlendRoot_M.blender' is locked or connected and cannot be modified. //
copyKey -t ":" -f ":" -at "c1r" Dana_Rig_v1_7:ScaleBlendRoot_M;
// Result: 1 // "
In the Channel Control editor there is no option to unlock any feature. How can I solve this? I need the complete controller to be unlocked so I can move the rig.
jmreinhart
It sounds like that attribute is keyed in the file you are referencing. That's what's stopping you from being able to edit it. Just go into the file you are referencing and delete the animation.
Sorry, I didn't get you. Even if I key the pose after several trials still it doesn't work as optimal. For instance, if I manage to key the pose bending knees at keyframe 80, and I go back to frame 1, the pose remains with knees bended whereas I would expect it to be in an upright position with straight legs. It won't work. I need the pose to start straight from frame 1 and incrementally bend the knees at frame 80. How do I check the thing you say?
jmreinhart
If you set your first key with the knee up on frame 80 and go back to frame 1 the knee will still be up. You'll need to set a key on frame 1 with the knee down. Just because you've changed the attribute in the channel box, that doesn't mean that you've created a key. You need to press "s" to key all the attributes on the selected control, or right click and select "key selected attribute" in the channel box.  You can also look up "auto-key" in your settings.
But I don't want knees down in frame 1. I want them up and slowly go down at frame 80. This can't happen because of the error message I explain in this post, whenever I press "S"
jmreinhart
Did you check this? If you need clarification let me know.
How do I do that? Please explain steps
I removed all references from the specific controller using the path File -> Reference Editor but still it won't allow key framing. Same error message.
jmreinhart
Go into the reference editor.
Find the filePath of the rig that is being referenced.
Copy that filePath.
Open that file.
Check if there is any animation on the controls.
If there is, then delete it.
Save the file.
Open your animation scene again.
I am using that version of Maya and Reference editor. How can I follow the procedure you describe?
Copy that filePath.
Open that file.
Save the file.
jmreinhart
Looking at that image, it seems like you didn't reference the rig. So the problem is coming from something else. My suggestion won't work then.
aallam_hatim
Community Visitor
Community Visitor
Thank you men you saved my life :')
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
