Hi everyone.
I just animating a character using FK in arms. Is it possible to do the hand remains in a specific location? ¿Is there any way to achieve this? ¿Is it possible with IK?
I want the character takes a rock from the ground, but if I apply "stretch" to the arms, these follow the body and... So you can imagine my mindblowing trying to fix the hand in the same place putting keyframes. ¿Can I do the same as photo? thanks!
Solved by charlyo46. Go to Solution.
Solved by gautham.chandran47. Go to Solution.
Oh my...! I forgot to change the stretch from 0 to 1 for achieve this! Now I can animate it perfectly! Thank you so much!
