This is happening with multiple rigs with multiple files, new files and old files. It flickers and moves as I scrub. I have the geo layers locked. It happens with modded and non-modded rigs. I’m using Maya 2019.
Are my files corrupted? Is my Maya license the issue?
If you have any other questions, I will do my best to answer.
Solved by kelly_hynes. Go to Solution.
Can you try disabling GPU Override in the Animation < Evaluation prefs.
Kelly
Kelly Hynes
Manager, Software QA Engineering
Installation & Licensing forums | Contact product support | Autodesk AREA
did you make the rigs? It looks like the hair is dyanmic. and so scrubbing it would be out of step.
if you play from 0 does it move nicely?
Amazing! This worked! You're a miracle worker. Any ideas why the GPU Override option was the key?
I can't say exactly what the problem is by looking at the images. But I recognize the broken mesh issue.
Be sure you are using the most recent update of your Maya version and most recent update of your graphics driver as this could solve the problem as well.
Kelly
Kelly Hynes
