Animation Layer issues with adding multiple objects
proofofchaos.animation
I have been having issues for a little while now. When I would try to create animation in the new layer the keys seemed to be created on the base layer.
After a bit of investigating it seems there is an issue with adding everything that is selected to the new animlayer. I select all the controls for my rig and try to a new anim layer or "create layer from selected". Both options do not allow me to add all I have selected. It will allow me to manually add every single control separately but be very inconsistent when I grab multiple controls.
Sometimes this is an issue sometimes its not..
Some help would be very much appreciated.
E
kaehwai
Community Visitor
Community Visitor
I have a similar issue with maya2022
kelly_hynes
Would you be able to provide simple repro steps that clearly show the issue you are having?
Thanks, Kelly
Kelly Hynes
Manager, Software QA Engineering
Installation & Licensing forums | Contact product support | Autodesk AREA
mthanish
Community Visitor
Community Visitor
I have the same issue with maya 22
jan_taaks
Community Visitor
Community Visitor
I also got the same issue, that I can not add multiple objects to an animation layer with Maya 2023.
As it is still possible to add controls one by one, I wrote this simple workaround script:
# get current selection and put it into list
AllObjects = cmds.ls(sl=True)
cmds.select(clear=True)
# adds every single object to "AnimLayer1"
for x in AllObjects:
cmds.select(x)
cmds.animLayer("AnimLayer1", edit= True, aso=True)
