Animation and Cameras
christophergainz
christophergainz
Hello what is the easiest way to create a turntable animation (preferably where the base of the character rotates and not a camera orbit of the object)?
Specifically I want half a timeline of a normal camera perspective and then a close up zoom of a particular area of the object all the while it is still rotating for the remaining timeline.
I can't seem to figure out the best way to do this and also how to merge this into a seamless animation.
Thank you
Kahylan
Hi!
1) Put all your Objects in a group
2) set a Keyframe on the group at the beginning of the Timeline when the Groups rotation ise 0,0,0
3) set a Keyframe at the end of the timeline with the rotation being 0,720,0
4) go into the Grapheditor and put the animationcurve to linear
5) Set a keyframe on your camera in the first perspective in the middle of your timeline
6) go 10 Frames forward and set a keyframe on the camera in your closeup perspective.
I hope it helps!
