angle of joint for pole vector
yatishtikone1999
Observer
yatishtikone1999
Observer
Observer
hi, is there any set angle of joints for arm rig so that it wont mess up my pole vector
see the video and tell me whats wrong
2024-03-13 04-00-50.mkv
Video Player is loading.
Current Time 0:00
Duration 1:40
Loaded: 9.77%
Stream Type LIVE
Remaining Time 1:40
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    Kahylan
    Hi!
    Your problem here, is that the XZ Plane of your shoulder joint isn't facing in the same direction as the XZ Plane of the elbow and wrist joint. And this isn't actually a pole-vector problem but an IK-Handle problem, as you can see at 0:44 in your video, your joints pop out of position when you apply the handle.
    If you want to ensure the best results when using IK-Handles and Pole vectors, your Joints should be oriented after these two rules:
    1) The Primary Axis and the tertiary Axis (in this case X and Z) of all Joints should all be within the same 3 Dimentional plane.
    2) The secondary Axis of all joints should stand perpendicular to this plane facing the same side
    In your case, the XZ Plane matches for Elbow and wirst, but not for the shoulder joint.
    What you are doing with the pole vector is correct.
    i hope it helps!
    yatishtikone1999
    Observer
    Observer
    hi I tried u r solution as I understood Can u please check if this is ok . still its not going right can u tell me how to fix shoulder orientation AND the thing is its getting right in T pose characters but I couldn't figure it out with othe characters
    mcw0
    Your method of placing the pole vector control is interesting.  But might I suggest a more direct approach.  When an ikHandle is created, the pole vector values are given to you.  You can use those values local to your start joint as the position for your pole vector control.  Now this will only be one unit away from your start joint so not very useful.  I noticed you want to place your control so that it's inline with the mid joint.  So you can just scale that pole vector value and slide it down the pole axis.  Straightforward math.  By using the given pole vector values, it's guaranteed that your joints will not move.
    Type a product name
    ______
    icon-svg-close-thick
    Cookie preferences
    THIRD PARTY SERVICES
    icon-svg-hide-thick
    icon-svg-show-thick
    Qualtrics
    Akamai mPulse
    Digital River
    Dynatrace
    Khoros
    Launch Darkly
    New Relic
    Salesforce Live Agent
    Wistia
    Tealium
    Upsellit
    CJ Affiliates
    Commission Factory
    Typepad Stats
    Geo Targetly
    SpeedCurve
    Qualified
    icon-svg-hide-thick
    icon-svg-show-thick
    Google Optimize
    ClickTale
    OneSignal
    Optimizely
    Amplitude
    Snowplow
    UserVoice
    Clearbit
    YouTube
    icon-svg-hide-thick
    icon-svg-show-thick
    Adobe Analytics
    AdWords
    Marketo
    Doubleclick
    HubSpot
    Twitter
    Facebook
    LinkedIn
    Yahoo! Japan
    Naver
    Quantcast
    Call Tracking
    Wunderkind
    ADC Media
    AgrantSEM
    Bidtellect
    Bing
    G2Crowd
    NMPI Display
    VK
    Adobe Target
    Trendkite
    Hotjar
    6 Sense
    Terminus
    StackAdapt
    The Trade Desk
    RollWorks
    Your experience. Your choice.
