It is my first time that I have ever rigged and I am using Advanced Skeleton. At the moment I am doing the face rig and I am attempting a Joint type rig. In the Fit section where you select edge loops on your model and then select 'EyeLidOuter', 'EyeLidMain', 'EyeLidInner' etc I am encountering some errors. When I select the outer edge loops around the eye and selct 'EyeLidOuter' the guides form fine around the eye and it works. However, when I select 'EyeLidMain' and select the main eye lid edge loops I get an the error -
// Error: file: C:/Program Files/AdvancedSkeleton5/AdvancedSkeleton5.mel line 17738: The source attribute 'model:Bunny_face_geo model:Bunny_body_and_face_geo.outMesh' cannot be found. //
The guides do not form around the eye lid.
I have searched everywhere and I just don't know what this means. I get the same error when I move onto the mouth area. When I select the edge loops around the outside of the mouth/lips and select 'LipOuter' the guides form around the mouth and everything is fine. However, when I select the edge loops closer to the inside of the mouth I get the same error again.
I am wondering if this an error on my part and if so I was wondering if I could get some help on how to rectify it.
Any help or advice would be greatly appreciated,
Thank you
Solved by jmreinhart. Go to Solution.
Does the attribute in the error exist?
Hey, it's okay I managed to fix it by editing Delta Mush and going back and re starting the masking. I didn't have the outMesh node either. Thank you so much for your help!
Hi, I got the same error message when I tried to make the EyeLidInner in advanced Skeleton
// Error: file: C:/Users/utilisateur/OneDrive/Documents/maya/scripts/AdvancedSkeleton/AdvancedSkeleton.mel line 23866: The source attribute ‘.outMesh’ cannot be found.
But I don't know how to solve this problem
