Maya Animation and Rigging
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya animation topics.
Advances Skeleton Error
5 REPLIES 5
s53247982F6VL
2071 Views, 5 Replies
It is my first time that I have ever rigged and I am using Advanced Skeleton. At the moment I am doing the face rig and I am attempting a Joint type rig. In the Fit section where you select edge loops on your model and then select 'EyeLidOuter', 'EyeLidMain', 'EyeLidInner' etc I am encountering some errors. When I select the outer edge loops around the eye and selct 'EyeLidOuter' the guides form fine around the eye and it works. However, when I select 'EyeLidMain' and select the main eye lid edge loops I get an the error -
 // Error: file: C:/Program Files/AdvancedSkeleton5/AdvancedSkeleton5.mel line 17738: The source attribute 'model:Bunny_face_geo model:Bunny_body_and_face_geo.outMesh' cannot be found. //
The guides do not form around the eye lid.
I have searched everywhere and I just don't know what this means. I get the same error when I move onto the mouth area. When I select the edge loops around the outside of the mouth/lips and select 'LipOuter' the guides form around the mouth and everything is fine. However, when I select the edge loops closer to the inside of the mouth I get the same error again.
I am wondering if this an error on my part and if so I was wondering if I could get some help on how to rectify it.
Any help or advice would be greatly appreciated,
Thank you
5 REPLIES 5
jmreinhart
in reply to: s53247982F6VL
Does the attribute in the error exist?
s53247982F6VL
in reply to: jmreinhart
No, nothing is named with .outMesh
jmreinhart
So no attribute like this?
s53247982F6VL
Hey, it's okay I managed to fix it by editing Delta Mush and going back and re starting the masking. I didn't have the outMesh node either. Thank you so much for your help!
Hi, I got the same error message when I tried to make the EyeLidInner in advanced Skeleton
// Error: file: C:/Users/utilisateur/OneDrive/Documents/maya/scripts/AdvancedSkeleton/AdvancedSkeleton.mel line 23866: The source attribute ‘.outMesh’ cannot be found.
But I don't know how to solve this problem
